ACHTUNG!!! KEIN REIFEN FUR LC8!!!
caballeroOffline
Anmeldungsdatum: 12.12.2002
Beiträge insgesamt: 305
BeitragVerfasst am : Mo, 23. Jun 2003, 13:53    Titel: Antworten mit Zitat
in italy is impossible to have KAROO 2.... Sad at this moment not producted....
but also SKORPION A/T!!!!!! Mad
in august i go to nordkapp and i have to change tires!!!!
how is the situation in germany/austria/swizerland?????
<span style='color:orange'>Ciao Matteo - KTM 950 ADV S n.1298 "caballeroarancio"- Sondrio - Italia
www.lc8.org
www.quellidellelica.com
www.advrider.com
nick:barbasma</span>
StollenritterOffline
Beiträge insgesamt: 204
BeitragVerfasst am : Mo, 23. Jun 2003, 14:14    Titel: Antworten mit Zitat
AT www.butzner-motorradreifen.de you may buy:
150/70 R 18 M/C 70H MCE Karoo
Bestellnummer: 1268800
Unser Preis: 103,00 EUR
90/90-21 M/C 54R MCE Karoo 2 Front M+S
Bestellnummer: 1203100
Unser Preis: 49,50 EUR
The tires are on stock, I just phoned them and asked for you.
Problem: They do not like to deliver to Italy, but try to contact them... there is always a way!
Greetings
DIRK
Benutzer-Profile anzeigen Website dieses Benutzers besuchen MSN Messenger
caballeroOffline
BeitragVerfasst am : Mo, 23. Jun 2003, 15:25    Titel: Antworten mit Zitat
thank's a lot...
but....
there's no SCORPION that LC8 mount... is a special tire with code "V"... (240 kmh max)... Mad
this shop have the model with "H" code... Sad
www.lc8.org
www.advrider.com
BeitragVerfasst am : Mo, 23. Jun 2003, 16:01    Titel: Antworten mit Zitat
Hi Matteo
Between Delebio and Morbeno is a Distributore per Gomme (Idustrial Zone, green Building).
He has most time some standart tyres for motorbikes on stock, ask him.
Very good service and fine equipment
Regard's Peter
KlapphelmfahrerOffline
Anmeldungsdatum: 12.05.2003
Beiträge insgesamt: 164
BeitragVerfasst am : Mo, 23. Jun 2003, 16:07    Titel: Antworten mit Zitat
Ciao Matteo,
io prendo le gomme da moto sempre da Holert Konz a Rosenheim o a Monaco in Germania. Se telefoni qualche giorno prima, ti procurano tutte le gomme a un prezzo molto inferiore che in Italia. Se vai al Capo Nord puoi passare lì direttamente all'inizio del tuo viaggio.
Gli indirizzi:
Holert Konz Meglingerstraße 15
81477 München
Tel (0 89) 78 29 12
Fax (0 89) 78 67 85
Kufsteiner Straße 69
83026 Rosenheim
Tel (0 80 31) 3 56 26-3
Fax (0 80 31) 3 56 26-40
Sul sito trovi anche altri indirizzi in Germania:
www.holertkonz.de
Ciao Berni
Obn bin i, des isch koa Zweifel, wia i wieder oikimm des woaß der Teifl....
Zuletzt bearbeitet von Klapphelmfahrer am Mo, 23. Jun 2003, 16:15, insgesamt einmal bearbeitet
caballeroOffline
BeitragVerfasst am : Mo, 23. Jun 2003, 16:22    Titel: Antworten mit Zitat
@bruggma
vielen danke!!!
@klapphelmfahrer
grazie mille...
il problema è che siamo di fretta... solo due settimane...dubito che riusciremo a fermarci per un cambio gomme...
ho fatto una ricerca su internet... non esistono le gomme 150/18 a codice V con indice di carico 70....
un mio caro amico fa il gommista e dice che il distributore per il nord italia non ha notizie delle gomme per l'LC8... Sad non le hanno ancora prodotte come ricambio.. solo come primo equipaggiamento...
mi ha detto che capita sempre quando fanno pneumatici specifici.... anche per la BMW X5 i clienti hanno aspettato mesi per avere le gomme!!! Mad
spero di avere notizie entro fine luglio...
lo stesso problema c'è per avere le camere d'aria da 150/18... devo portarle come ricambi...
www.lc8.org
www.advrider.com
BeitragVerfasst am : Mo, 23. Jun 2003, 16:39    Titel: Antworten mit Zitat
Puoi provare a contattare KTM Sommer, se ti possono procurare e spedire le gomme con un corriere.
Naturalmente è una soluzione un pò costosa.
Buona fortuna
Berni
Guest
BeitragVerfasst am : Mo, 23. Jun 2003, 18:04    Titel: Antworten mit Zitat
Klapphelmfahrer hat folgendes geschrieben:
Buona fortuna
Berni
der Reifenversand in das Ausland ist seit Anfang Juni extrem teuer geworden und praktisch nicht zu empfehlen. Wenn der 950er Fahrer von Italien zum Nordkap fährt, kommt er "praktisch " bei uns vorbei. Dann kann z.B. so ein Reifensatz ambulant gewechselt werden.......
Wir haben viele 640er Adventurekunden, welche per Achse aus Skandinavien kommen, in Oberhausen Umbauten vornehmen lassen, danach nach Köln fahren und dann weiter per Autoreisezug nach Port Bou/Narbonne.....
caballeroOffline
BeitragVerfasst am : Mo, 23. Jun 2003, 18:25    Titel: Antworten mit Zitat
Guest hat folgendes geschrieben:
Buona fortuna
Berni
@SOMMER KTM
vielen dank....
so the tires exist in germany!!!
so why not in italy????? Mad Mad Mad
www.lc8.org
www.advrider.com
BeitragVerfasst am : Mo, 23. Jun 2003, 19:35    Titel: Antworten mit Zitat
Hi Matteo
Why did you dont check the dealer list for dealers in Engadina ore Ticino.
If you cant find someone, all tyres in switzera are distributet over
Hostettler AG
Haldenmattstrasse 3
CH-6210 Sursee
Tel.: 041/ 926 61 11
Fax.: 041/ 926 62 93
Internet:
www.hostettler.com www.yamaha.ch
info.hostettler.com
caballeroOffline
BeitragVerfasst am : Mo, 23. Jun 2003, 21:33    Titel: Antworten mit Zitat
Bruggma hat folgendes geschrieben:
Hi Matteo
Hostettler AG
Haldenmattstrasse 3
CH-6210 Sursee
Internet:
info.hostettler.com
@bruggma
vielen..vielen..vielen dank!!!!
www.lc8.org
www.advrider.com
maddanOffline
Anmeldungsdatum: 07.01.2003
Beiträge insgesamt: 11
BeitragVerfasst am : Fr, 27. Jun 2003, 11:24    Titel: Antworten mit Zitat
hoschi kann ich nicht empfehlen. teurer als bei hostettler in sursee wird man nirgends einen reifen kaufen Mad er hat den GENERALIMPORT, d.h. das metzeler monopol für die CH. jeder eigenimporteur (selbsständiger reifenhändler) wird von hoschi knallhart sanktioniert und mit nichts mehr beliefert.
hole meine marathon immer in DE. kosten 50% weniger als in der ch. z.b. bei www.reifenversand.com
caballeroOffline
BeitragVerfasst am : Fr, 27. Jun 2003, 11:34    Titel: Antworten mit Zitat
i've found the tires in TICINO (CH)... but i'm waiting in italy beacause in CH are more expensive... Sad
www.lc8.org
www.advrider.com
BeitragVerfasst am : Fr, 27. Jun 2003, 12:06    Titel: Antworten mit Zitat
@caballero
Dont buy tyres by a offical bike dealer, tyre discounter in Switzera interna are much cheeper,
cheeper then Distributor di Gomme in Italy.
Hallo Maddan
Ich habe mir gerade einen Satz Michelin Anakee gekauft.
50% auf Listenpreis, Räder demontieren, montieren SFr. 10.- € 7.50
Das ist derselbe Rabatt den ich auch auf die Metzeler Tourance bekommen hätte.
Woher die Dinger kommen, ist mir ehrlich gesagt gleich.
caballeroOffline
BeitragVerfasst am : Fr, 27. Jun 2003, 12:40    Titel: Antworten mit Zitat
@caballero
Hallo Maddan
danke...
www.lc8.org
www.advrider.com
[ Time: 0.1475s ][ Queries: 26 (0.0749s) ]
